Catalytic Converter Problem???
Old Sep 14, 2001 | 01:07 AM
92GTA's Avatar
After I cleaned my engine at my local do-it-yourself carwash my engine ran perfect for the 2 miles trip home. I went out an hour later and sprayed Eagle 1 tire gloss all over everything then drove to the store. Just as I pulled into the parking lot I noticed the engine was not idling right. When I came out of the store it started right up but about 1/4 miles into the 1 1/2 miles trip home. It totally lost power, when you push the accelerator, nothing. I was able to get to a near by parking lot where the car stalled. I opened the hood and the entire bottom of the exhaust manifold and the catalytic converter where glowing RED hot! I tried starting the car but it only would start, idle, then die. I walked home and came back about 4 hours later. The car started right up but after about 20 seconds it was idling bad again. I was barely able to get it home it only took about 60 seconds to get up to full operating temp, it did not overheat though.
What's going on???? The is my only transport aside from my GTA. It's a '93 Toyota Corolla that before this always ran perfect. It has 107,000 miles on it now. Does it have to do with the water on the engine, the eagle 1, or did my cat just go out finally?????? I know I'm going to have to replace my oxy sensor because it is right above the cat in the bottom of the exhaust manifold.
Thanks in advance, I need the car to get to work....
www.TransAmGTA.com THE 3rdgen Firebird Site!
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, EVERY available option except U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
Old Sep 14, 2001 | 11:18 AM
92GTA's Avatar
No one can help me out?
Old Sep 14, 2001 | 11:25 AM
AntiVTEC's Avatar
YES CHANGE THAT 02 sensor! It could be causing your car to run super lean, which would explain the red glow. Have you been doing regualr maintenence on the car?
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Sep 14, 2001 | 11:28 AM
92GTA's Avatar
Yes, the car has been mainained just as well as my GTA. I know the o2 sensor is good but maybe I got water on the connector for it.....
Anyway, I have the smog the car next week so I'll go ahead and replace the cat and the o2 sensor if I can get it to a muffler shop, I just want to know if that will solve my problem so I don't blow out the new cat and o2 sensor?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
gta power
Aug 13, 2015 06:15 AM
