A/C smoking?
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
A/C smoking?
Ok, so I have an interesting problem. lately around here it has been around 100 degrees daily so I have been using my a/c. usually I don't but it has been too hot not to. and today i was drivin and I noticed like a white haze coming out of all my vents, but it was only when I had the a/c on, not when the vent was on. this happened last year in one of my friends' cars. he has a 94 Honda Accord (GAG). i was just wondering if anyone had any kind of explanation for this cause it just struck me as odd.
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
from what i hear is that the Accumalator is probably cloggin up or needs the orifice cleaned out . This just means that it might have restriction makin it much more colder than usual and this will lead to some problems later.
Alot of people like to say " yeah it blows ice cold, you can even see smoke (mist) coming out the a/c" i heard this a couple of times and now i know what to tell them ...and sometimes they still deny it
Car: '89 IROC Z
Engine: TPI 305
No, the accumulator is not clogged, nor does the system get colder if the orifice tube is all plugged up!?!
What you are seeing coming out the vents is nothing more than water vapor. This is common when the heat and humidity are high and this is nothing to worry about. What's happening is simply that there is so much humidity in the air, that as the air passes through the evaperator, not all of the water is condensing and dripping down into the evaperator drain pan, and some is simply coming out the vent with the air stream in the form of water vapor. Relax and don't do anything to your A/C system. It is working properly.
Thanks 89Z. that was kinda my hunch but I just wanted to check and make sure because I don't know a WHOLE lot about a/c. especially since I hardly ever use it. and yeah the heat and humidity are very high around here right now, so that makes a lot of sense. thanks again.
off topic, but 1989karr it sounds like you have my car. i too have an 89 firebird 2.8 with a slipping 700r4...its so depressing.. I wish tranny rebuilds wern't so expensive... and I wish i had the money to just do a t5 swap.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Really? Yeah I agree....the price of tranny rebuilds and paint jobs are sorely expensive
...almost makes me want to cry
yeah. I feel for ya, at least I am not alone.. but yours probably wasn't your fault like mine was... I made a dumb mistake when racin at cordova and screwed it over...
Engine: 3.4 / 5.0
Engine: 3.4 / 5.0
yeah i have an oil leak too. just a small one though. it sucks, but I don't have the money to fix everything so I just gotta do what I can.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Originally posted by 1989karr
haha I know were going off topic more, but don't worry. On top of that I got a very nasty oil leak, a worn timing chain, and some blue smoke on start up! lol
I hear that stop-smoke crap works pretty well...you can find it at almost all auto parts stores. Smoke on startup is a general indication of valveseals....which is really no big deal to fix. Rings is smoke all the time, valveseals is just generally on startup, due to oil leaking down past them into the cylinders.
And for the tranny...try adjusting your line pressure a little bit at the TV cable, there's a tech article on the site for it. And also, another "miracle additive"....Lucas Transmission Fix. I've used this stuff in all of my auto trannies except the brand brand new one....and lemme tell you it's pretty amazing. My old AOD trans, went from slipping pretty bad....to barking second gear and holding together very well.....lasted about 2 months this way. And this trans had over 150,000 miles and was behind a modified engine... That additive REALLY helped, I was stunned at the difference. Well worth the cash, IMO.
And USUALLY, I don't advocate additives at all. Only ones I run are Lucas products, just the injector cleaner and trans additive, and then Engine Restore....
Engine: 3.4 / 5.0
oh wow, those sound like some goos tips! Plus they sound like they are in my budget! I will try those when I get a chance. Thanks!
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: A/C smoking?
hey Nixon1, I have seriously thought about that tranny additive, but after reading around on here people say that they do more harm then good... i have 150,000 miles on it and its never been rebuilt, nor do I have the money to do it.. should i reallytry the additive? I dont' want to f it up worse than it already is. and I did adjust my line pressure...didn't change anything.
alright, I might look into trying it. thanks for the reccomendation
2012sergen11
Oct 13, 2015 07:38 PM
