Plug change on 1991 Trans Am
Old Sep 14, 2001 | 05:38 AM
dp149's Avatar
I am a shade tree mechanic at best and was wondering if somebody can give me some tips on how to get the plugs out of my 1991 5.7 trans am. If somebody who has a similar car can tell me what size socket and procedures to remove them (i.e. from top or bottom of car) that would be great. Also, should I do this when the engine is hot or cold and should you put antiseize on the threads ? Like I said I am amateaur at best but feel I can replace spark plugs.
Thanks for your time.......
Old Sep 14, 2001 | 09:50 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
On my 91 GTA (prior to installing the headers) w/AC, I had to get at ALL plugs (except #1) from under the car.
It used a standard spark plug socket in any socket set, but I also had to use a variety of extenstions. Some none, some 3" and a couple I had to use 3/8 to 1/2" adapter plugged into a 1/2" to 3/8" adapter to make the extension only 1 1/2".
Believe it or not, I found headers actually made it easier to get at. With my Edelbrock TES, I can get at all the driver's side and #2 on the passenger side from topside. Only # 4, 6 and 8 need to be gotten at from underneath.
With headers, I took a spare spark plug socket and ground about 3/8" off the top. Then I use a "ratchetting box-end" on the end of the ground off spark plug socket to access the plugs. The tip of the plug pokes through the end.
Old Sep 14, 2001 | 12:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would recommend making sure the engine is cool, unless you have protective gloves that will cover most of your arm. An engine block can seriously get hot. I've tried removing the plugs after running the car and letting it cool for awhile, not sure how long but at least 1/2 hr. and the block still burned my hands a little.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 14, 2001 | 02:22 PM
un4givin89's Avatar
I changed two of my plugs today to see if I could do it. The first two on the drivers side, easy, but all the rest look like they are gonna be tough. But I have an Camaro, so I dunno if its any different. I hear headers make it easier to get to them. I dunno.
un4givin89
1989 Camaro Ralley Sport, 305 TBI 5 Liter v8
Project List:
Crate 383 Engine
Flowmaster Exhaust
New Tires
Windows tinted
Interior swapped for two tone colors
Lowering Springs
Sound System
www.mikekey.net
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
jharrison5
Aug 19, 2015 05:53 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
