STP
Old Sep 13, 2001 | 09:19 PM
91TA's Avatar
STP
Not sure where to post this so I will put it here. Just wanted to know what STP stood for. thanks..
Old Sep 13, 2001 | 10:00 PM
Vader's Avatar
STP is a trade name for an oil-fortifying product. Some people have speculated that the acronym stands for "Super Thick Petroleum", or something like that. I've never seen the "official" answer to this speculation.
It makes a reasonably good engine assembly lube if you intend to build an engine and stick it on the shelf for any length of time before running it in and putting it in service.
It really isn't that good as an engine oil additive, unless your engine is worn so badly that it smokes constantly (like Mitsubishi engines in Dodge Caravans). As a regular lubricant additive - don't even think of it. Modern engines operate with closer tolerances and materials that are engineered to maintain the tight fits so that extra thick lubricant isn't a good idea. Your grandfather may swear by it, but it was helping to nurse along his model A or DeSoto, not a modern vehicle. Just like you probably wouldn't put alcohol in your radiator as an antifreeze, you shouldn't use these products except as a temporary last resort before replacement or rebuild.
Later,
Vader
Justice and Freedom will Prevail
Old Sep 13, 2001 | 10:02 PM
91TA's Avatar
Thanks for the help
Old Sep 14, 2001 | 05:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
STP oil treatment is nothing more than the same additive used to make multi-viscosity oils - viscosity index improver. It is a polymer chain that expands with heat to take up the space between oil molecules to keep the oil thick at higher temps. This polymer chain is also the first thing to break down under shear (like crank bearings pistons skirts, cam lobes, and rocker arms) and heat.
If you like the sludge- and varnish-producing properties of multi-viscosity oils, then you can enhance it by adding STP oil treatment. If not, like the rest of us, then stay away from that stuff.
FWIW, I thought the "S" had something to do with "Studebaker". But, the last time I heard that was about 30 years ago...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 14, 2001 | 09:12 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
Surprised this stuff is still around. Wonder what happened to Bardahl?
Old Sep 14, 2001 | 11:22 PM
Guest
Guest
Posts: n/a
I used to know... Ill have to see if I can jar my memory.
I am pretty sure its S??????T?????? Products... hmmm maybe Ill remember before the next decade ends
Just did a search for the heck of it... I am about 90% sure the last letter did stand for products, but their company name (Division of Clorox LOL) is STP Products. So, its ST Products Products. LOL!
Bardahl is still around, although scarce.
STP is great for a car that smokes that you are gonna sell. Otherwise, I wouldnt use it.
[This message has been edited by madmax (edited September 14, 2001).]
Old Sep 14, 2001 | 11:26 PM
rezinn's Avatar
I read somewhere that it stands for Scientifically Treated Petroleum.
Thornburg
Sep 1, 2015 03:39 AM
customblackbird
Aftermarket Product Review
207
Jun 10, 2010 01:36 AM
Crux
Exterior Parts for Sale
Apr 10, 2008 01:24 PM
Kj Rockz
Oct 23, 2002 11:48 PM
Sciguyjim
Jul 8, 2002 05:17 PM
