mystery problem ???
Old Jun 29, 2005 | 06:02 PM
Foltron40000's Avatar
mystery problem ???
The car is a 1991 Z28, the problem started when it wouldn't start by turning the key but was solved by running power directly to the starter . After driving for a day using the jumping the starter method the car just died. It could be started, but when i put it into gear and began to move the car dies. it can be revved to redline while in park or neutral, but when in gear it dies within a few feet of movement. i have already replaced the ignition switch and neutral safety switch and i'm stumped now. any input would be helpful .
Old Jun 29, 2005 | 06:08 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Have you checked to see if you have any trouble codes?
Old Jun 29, 2005 | 06:10 PM
yes i got a code 46, but dont know wat needs to be replaced in the VATS system
Old Jun 29, 2005 | 06:30 PM
fbodytransam's Avatar
Car: 1988 z28
Engine: 305 4bbl
i could be some kind of temp sensor that same problem happend to my buddy the sonsor was telling the car it was 40 below i dont remember whaat the part was called if you dont solve the problem by tomorrow i will get you the name
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
