wut are stock GTA wheels made of?
Old Sep 14, 2001 | 09:03 PM
breathment's Avatar
I know this sounds stupid, but i need to buy some wheel cleaner, and the A-2-Z wheel cleaner comes for different types of wheels, and i dont wanna buy the wrong kind. also wut kinda polish should i use? i have some chrome polish, would that work?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 14, 2001 | 11:18 PM
Guest
Guest
Posts: n/a
Chrome polish is way too abrasive. Get some clearcoat safe cleaner, preferably one that wont eat paint either, and use nothing more abrasive than something like Meguiars fine cut cleaner wax, otherwise you will take a bunch of the coating off the wheels, and you dont wanna do that.
The wheels themselves are cast aluminum with a machined lip, painted centers, and some sort of weird clearcoat thats kinda like a plastic of some sort.
Old Sep 14, 2001 | 11:40 PM
poncho9789's Avatar
The gta wheels are made of aluminum the best thing I have found is the new armorall wheel cleaner that is in a silver bottle. you the other thing that I use to clean mine is a mag brush that I found at autozone it is a thin wire with bristles on it and all i do is coat the wheels in cleaner and brush inbetween the holes. also use mothers on the pollished lip that is the best thing I have found. be shure to use a polishing cloth as to not scrach the wheel.
have funn it takes me about a hour to clean and polish all my wheels.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NO2. This car is currently under rebuild and restoration.
Old Sep 15, 2001 | 12:15 PM
breathment's Avatar
i remember reading on the back of my A-2-Z wheel cleaner that i was not supposed to let it stay on the wheels for longer then 15 seconds, and should i get the MAG wheel cleaner, the aluminum wheel cleaner, or the painted\clearcoat wheel cleaner?? because i know that one of them says it cannot be used with aluminum wheels
http://www.eagleone.com/products/pro...06&itemid=1003
- David
[This message has been edited by breathment (edited September 15, 2001).]
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
kah992
Aug 19, 2015 02:55 PM
dhonda200
Aug 11, 2015 11:50 PM
mustangman65_79
Aug 9, 2015 03:00 AM
