fuel pump,filter,or relay?
Old Jun 29, 2005 | 11:14 PM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
ok guys i let my sister borrow my car and she the gas tank dead empy and now my car wont start. the fuel pump was kicking on and off but now when i turn the key i hear nothing and i tried releiving the presure by the valve behind the intake manifold and still a no go. do you think its the relay or do you think that its the pump itself? and how hard is it to cahnge the pump? should i give it a go myself or pay somebody to do it?
also since ive never doen this before could anybody give me a step by step on how to remove and install a fuel pump and relay. i would greatly appreciate it
Old Jun 30, 2005 | 03:36 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
first thing to do is check and see if its the relay or the pump. I would check your fuses and make sure the engine control fuse isn't blown. Next follow the steps in this thread:
fuel pump
If you find its the relay then just buy one and replace it. Its on the driver side firewall. If its the pump then its a pain, just do some searches here and you'll see. I think you have to drop the rear axle to get it out. Good luck
Old Jun 30, 2005 | 03:41 AM
Car: 91 Z28
Transmission: 4l60e
wait where is my relay at? there is a little round thing thats attached near the middle of the car and the fuel line goes to it is that my filter or what is it?
edit: oh by the way i checked my fuse near the battery and its good. and there was no pressure when i checked the valve on the fuel rail
Old Jun 30, 2005 | 09:33 AM
jasman19's Avatar
Engine: 350 5.7L
The round thing your talking about is the fuel filter. The relay is on the driver side on the firewall. What I meant by the fuse is in your fuse box is the one labeled "eng cntrl". This fuse is for both your ecm and fuel pump, check that. The one you checked was a good idea anyways. Find the relay then follow the steps in the shortcut I posted and you'll find your problem. Its probably the relay, or atleast lets hope it is.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
