Open Elemenet Installed, AIT sensor
Old Sep 13, 2001 | 04:27 PM
un4givin89's Avatar
Maybe its in my mind, maybe.. I've been raicng around all day. My box came this morning from summit with my Elderbrock Open Element. My first mod. I installed the baby, and it sounds so much louder and like a growling. Its awesome. And while their is that small 5HP gain, I sware to *** I can tell the differance. It seems to be running better. Maybe its in my mind, but I think it is faster!
On question, that AIT sensor, it is AIT right?, what do most of you do with that. I moved it over by the A/C.
un4givin89
1989 Camaro Ralley Sport, 305 TBI 5 Liter v8
Project List:
Crate 383 Engine
Flowmaster Exhaust
New Tires
Windows tinted
Interior swapped for two tone colors
Lowering Springs
Sound System
www.mikekey.net
Old Sep 13, 2001 | 05:42 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
When I put an open element air cleaner on mine, I cut a hole and put the AIT Sensor in the new air cleaner base and it works fine, but I understand that the farther away it is from the heat of the engine, the better it will run. I've been told it'll richen the mixture a little, usually making more power.
Over by the AC should be fine, if you don't mind it flopping around over there.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Sep 13, 2001 | 11:06 PM
un4givin89's Avatar
Does anyone elses idile speed seem alittle smoother after the mood. I guess cuase the car is breathing better.
Old Sep 14, 2001 | 01:58 PM
GiddyUP305's Avatar
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:
Does anyone elses idile speed seem alittle smoother after the mood. I guess cuase the car is breathing better.</font>
i like the sound coming from the engine now, especially with the K&N and the new exhaust and z28 tips
&lt;marquee&gt;FIREBIRD...Flying lessons included:&lt;/marquee&gt;
Let the Pontiac Firebird show you how to soar, with over thiry years of engineering & technological advancements-including the Ram Air Induction--Under its wings..Its aggresive styling,outstanding performance & great value make it one rare bird
Old Sep 15, 2001 | 08:27 AM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
I did the same thing with my 9" x 3" open element. just bored the right size hole in the new base and put hte sensor in. Looks factory and works fine. Also no loose wires laying around.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old Sep 15, 2001 | 06:43 PM
Enkil's Avatar
It seems to me like it would be a good idea to put it inside the new air filter. The sensor IS there for a purpose, after all.. and while it won't make too big of a difference... I dunno, I'd just rather have it where it's supposed to be.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
