HEI info
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
HEI info
I just got my new Accel distributor in the mail the other day. I openned up the cap to find that the spring (can't think of real name) that runs from the coil to the rotor didn't even come through the bottom of the cap. I take the dust cover and coil out of the top of the dist. and see that the spring is sitting on top of the pad under the coil. I thought that the spring should be under the pad so that it could make contact with the rotor. If not, how does the spark make it from the coil to the rotor?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It was probably shipped like that to protect it.
Put the rotor button with spring in the cap so that it extends out the bottom. Install the pad. The spring should protrude out the top of the pad. Install the coil.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
3rdgenparts
May 21, 2016 11:50 PM
skinny z
Oct 5, 2015 06:23 PM
Linson
Oct 1, 2015 09:50 PM
Damon
Sep 26, 2015 04:29 PM
