Belts and pulleys
Old Jul 1, 2005 | 03:50 PM
mefang's Avatar
Car: 1985 Z28 IROC
Engine: 5.0 tpi ,mild cam,hypertech flat to
Belts and pulleys
Does anybody h-appen to have photos or somthing like instructions pertaining to my belts and pulleys,AC ,PS,Air pump and ,of course the alternator.I uh screwed up and didn't tag the various pieces and uhh.......HELP!I put my faith in my memory and it is failing me now, at this most in opertune time
Old Jul 3, 2005 | 11:49 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
sorry i don't have any stock photos,but the same thing happened to me once.just start trying bolts in different holes.there are only a few that you can mess up.if i remember correctly the worst one is the ac bracket,there is a metric head bolt that bolts to the back side of the bracket that is almost identical to a standard bolt that bolts the bracket to the front of the waterpump.
mine is an 86 and far from stock now,and the old brain cells are not clicking as well as they used to!
it took me about a day to sort it out,be patient!wish i could help more!i'll look around for pics of the bracket placement.if it's the same as the 86,the alternator is top left,a/c top right,p/s bottom right,and i never had an air pump on this one when i got it.
hope this helps get you started.
Eric B
Old Jul 3, 2005 | 11:52 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Mefang, do you know if the '85 is the same as the '86? I have some pics I took of my '86 when I pulled it.
Old Jul 3, 2005 | 11:54 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
OK, I found some BIG pics I took of mine as I disassembled it just for this reason. I'll email 'em to you.
Old Jul 5, 2005 | 03:26 AM
mefang's Avatar
Car: 1985 Z28 IROC
Sorry i've been slacking on the web scene.thanks for your replys .
Iceman,yes i beleive 85 and 86 are the samei'll look for your email now
thanks
bigjay89gta
Oct 15, 2015 08:04 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
jaridjohn
Oct 5, 2015 07:01 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
