Rocky Ride...
Old Sep 15, 2001 | 11:29 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Rocky Ride...
What are some good ways to soften the ride of an Iroc? For instance, do caddys just have really soft springs and struts, or is it something intrinsic to the whole setup that gives a soft ride? Don't get me wrong I'm a big fan of good handling, but I need to soften up the suspension a bit. I moved to a new, much bumpier area, and I want good handling, but when you're getting bounced around so badly on bumps that you can't steer or accelerate smoothly and you get mad wheel hop the car literally doesn't "handle" at all. Thanks in advance.
Old Sep 16, 2001 | 01:45 AM
mtx28's Avatar
look in a summit catalog under hotchkis.. i think they have a section just for you, called something like 'Spongy Springs: for those of you who demand the most caddy-like feel out of your sports car'.. haha, jk seriously. i dunno man, if you seriously want some sponge action, put some springs out of a v-6 camaro in there, that will soften it up a bit.. or throw a few hundred pounds of sand bags in the trunk and right behind your seat
83 Z28--not a pretty site, sold thank goodness
74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
"I wish I was a messenger and all the news was good..I wish I was the full moon shining off a Camaro's hood"
Old Sep 16, 2001 | 06:06 AM
Locry's Avatar
maybe you should change your name to "I SOFT"... for a softer ride... jk
Old Sep 16, 2001 | 03:35 PM
82camaro's Avatar
Car: 82 camaro SC
Handling is on the opposite end of smooth ride as far as a suspension goes. V6 springs, V6 sway bar in front, no bar in the rear will make it ride nicer(still not as good as a caddy) but handling will suffer. It's a trade off.
I'm guessing you won't get a good response here, since most of us make our cars handle better and ride harsher.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
[This message has been edited by 82camaro (edited September 16, 2001).]
Bradsaundry
Aug 12, 2015 12:34 AM
FSTFBDY
Apr 22, 2007 05:20 PM
FSTFBDY
Exterior Parts for Sale
Mar 25, 2007 09:21 PM
FSTFBDY
Jan 31, 2007 11:07 PM
irocbirdbuilder
Nov 30, 2005 08:17 AM
