how to select main bearing size
Old Sep 16, 2001 | 05:37 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
ok i'm rebuilding my shortblock first time i'm doing this, i'm trying to figure out what size main bearings and rod bearings to get, all the bearings in this motor are fine i just took it apart to replace the rings, do i get the same size bearings that came out or what?
Old Sep 16, 2001 | 06:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's about it.
You could also use a micrometer and check the crank size.
ICON Motorsports
Old Sep 16, 2001 | 08:13 PM
ede's Avatar
ede
you still need to know what bearings came out of it. as far as i know all bearings are maked std. or the amount of undersize. i'd measure the main journals and crank pins and buy my bearings based on the measurements.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Nick McCardle
Sep 10, 2015 08:36 PM
BOOT77
Sep 5, 2015 03:55 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
