no speedo
Old Jul 5, 2005 | 03:47 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
no speedo
i did a few searchs and didnt find much to help. i unhooked my dads ecm and a few more nearby connectors. the ecm hasnt been used since a year ago when he swapped engines. hes got a 86 ta. originally it was the carbed 305, automatic.
like i said the ecm is not being used. however the only thing that doesnt work now that stuff is disconnected is his speedo. is the ecm responsible for the speedo, or probably one of those other connections i unhooked?
Old Jul 5, 2005 | 05:41 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I'm not sure, but you can always check a service manual.
Old Jul 5, 2005 | 06:25 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
theres a cable connected to the trans,its a screw in cable connected near the rear of the tranny, its controls the speedo. if thats on there, check the one connected to the actual speedo in the dash.
Old Jul 5, 2005 | 06:50 PM
pellmanm's Avatar
Car: 1989 GTA
The cable could also be internally broken.
Old Jul 5, 2005 | 08:32 PM
Car: 89 camaro rs
Engine: 305 tbi
i hooked a few connectors back up and that didnt solve it. im pretty sure its a electric speedo, because as i crawled under it as much as far i could with out it raised i felt 2 wires going into a plug on the driver side of the tailshaft.
im going out of town for a while so ill hook stuff back up. and one day convert to a mechanical speedo. thanks guys.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
