Fixing overheating problems
Old Sep 17, 2001 | 08:50 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Okay all summer my car has been running hot. It normally stayed at about 220*, and if I raced anyone or got on the higway it would go as far as 230*. One day it got to 250* so I decided I had to fix it. First, I pulled the radiator and stock fan and fan clutch off. The radiator has som grass in the fins, so i vacuumed it out, then I flushed the radiator with water. BTW, previously, I was running 100% antifreeze. Now I am running half Antifreeze/half water. Also, I ditched my stock fan in favor of a flex fan with a solid mount to the water pump instead of the POS fan clutch. These mods alone made it run at 160* around town but it would still get to 220* on the highway. At this time, i did not have an airdam on the car. I removed it because it is torn up and is missing the lower part, so it only hangs down anyways. Yesterday at the junkyard, I found an airdam on a camaro, but its a different style than mine. Mine has multiple pieces and it curves from the radiator back to in front of the wheels. The camaro one only hangs down under the radiator and it hangs alot lower. Anyways, i put it on, and when I drove it to work this morning, it never got above 170, even going about 110 on the highway. The only downside is the airdam is ugly because it hangs down so far.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Sep 17, 2001 | 11:23 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would rather have an ugly air dam than my car running at or above 230*.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 17, 2001 | 01:12 PM
iroc5speed's Avatar
yeah, overheating is no good, mine had problems in that area the whole summer, and I ended up replacing the whole cooling system. good that you got that fixed. the air dam on my car is the one piece version that hangs down. I've never seen different air dams on third-gens than that.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Sep 17, 2001 | 02:50 PM
Biochem's Avatar
Car: 2002 SOM z28
I'd settle for ugly vs. overheating too. I have the one piece air dam as well on my 84.
I have just the opposite problem as you. Mine overheats in traffic, but is 160F on the highway (except on the very hot days). I attribute mine to that worthless 25% underdrive crank pulley I bought from March! Even on cool days like today (mid 60s) I was getting up there in temps...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Sep 18, 2001 | 07:34 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Yesterday I drove all the way home from work with the A/C on, and its a 30 mile highway drive. The car stayed at about 170* all the way. Whe i got off the highway finally, I was in rush hour traffic which is contstant stop and go, and the hottest it got was abotu 190*. I am very happy because I havent been able to use the A/C since i've had the car. Oh, btw, if anyone else with an overgeating LG4 or L69 wants to do these mods heres the prices.
Hayden Flex Fan - $25 at Pep Boys
Hayden 2" Fan Spacer - $17 at pep boys
Bigass Airdam from 88? Camaro - $10 from junk yard
Total cost: about $52
Using A/C: priceless... :P
1983 Firebird
TH700R4 Auto
Small Block 400
theshackle
Mar 5, 2017 06:37 PM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
dyeager535
Aug 28, 2015 08:10 AM
Bert87
Aug 23, 2015 03:50 PM
