.495 to much lift for factory Springs?
Old Sep 17, 2001 | 09:10 PM
uncle bobo's Avatar
I am pretty sure it is but thought I would ask anyway. That is the smallest roller cam I can find, are there any roller cams with about .475 lift that will make good power or should i get a bigger cam and springs also.
Old Sep 17, 2001 | 09:24 PM
Guest
Guest
Posts: n/a
The stock springs arent much good for a stock cam, let alone a decent one. IIRC the stock ones bind anywhere from .460-.490 depending on the actual spring used. I still wouldnt think of reusing the stock springs, they are pretty lousy as far as springs go.
Old Sep 18, 2001 | 03:09 AM
Raymond 5.7 89 Formula's Avatar
I second that. I changed my stock springs on the car when it had only 30,000 original miles on it when I put my Crane Roller rockers on and found out they had only around 40 pounds seat pressure at that time.
Old Sep 18, 2001 | 08:39 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I have a stock cam and i have valve float at about 3700 rpm... Stock springs suck
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
SlowAZ28
Sep 2, 2015 05:19 AM
