stupid ac/heater switch doesnt work
Old Jul 6, 2005 | 01:51 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
you know the top *** that controls the direction your ac or heat flows through the vents? no matter where i move that ***, the air always flows out the top defroster vents only. how can i fix this? its somewhat annoying
Old Jul 6, 2005 | 08:26 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Defrost is the default position when there is little or no vacuum for the HVAC system. Trace the vacuum lines that run to it, and check for cracks, tears, or unconnected lines.
Usually, the vacuum lines run from the vacuum reserve canister (round device under the the car below the charcoal canister), up the driver's side fender, across the firewall, to a 3-way vacuum check valve near the distributor, then down and through the firewall, and ending somewhere under the dash for the HVAC doors.
Old Jul 6, 2005 | 11:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ahh thats why.. thanks. i had removed them vacuum lines a long while back. forgot thats what they are for.
Old Jul 6, 2005 | 11:38 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
This is going into TraviZ' 'DOH' book I bet.
Old Jul 6, 2005 | 11:39 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yup definitely. good thing i only have heater anyways, i was just curious
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
The_Phoenix
Feb 4, 2016 07:10 AM
dhonda200
Aug 11, 2015 11:50 PM
Fronzizzle
Aug 9, 2015 01:15 PM
