help with vapor line from gas tank
Old Jul 7, 2005 | 12:23 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i was thinking.. since ive removed my charcoal canister, i still have that stupid metal line from the gas tank. is thier something i can do like run that line directly to my intake manifold? and if so i know the manifold will be sucking in vapor from the tank, so should i use a vented or sealed cap? i was thinking a sealed cap would create pressure in the tank and a vented cap would make my car act like a vaccuum leak. so im not sure. i dont know much about check valves but could i run something like that in line to have it only open at cruising speeds or what? i need some smart minds to help me figure this little unique application out.
yes i want some better milage but without have all the factory emissions equipment.
Old Jul 7, 2005 | 12:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Cap the line and use a vented cap, or keep the factory sealed cap and put something like a fuel filter or crankcase breather on the line.
Or you could just keep the charcoal canister.
Old Jul 7, 2005 | 12:38 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well what im trying to do with this is somehow run this line directly to my intake so i could use the vapors for a little better milage. so i want the vapors in my engine not exiting the gas cap.
Old Jul 7, 2005 | 12:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Keep the charcoal canister then. I doubt that a tiny amount of vapour would make any noticable difference in your mileage anyway.
Old Jul 7, 2005 | 06:55 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Remove the canister, rebend the line under the car, put a .99 cent fuel filter on the end of it. That's what I did....works fine.
Old Jul 8, 2005 | 04:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
just play with me here, i already have a set plan what i want to do, but i need your minds to help me figure a way to do this, i dont want to do it another way.
Old Jul 8, 2005 | 06:10 PM
406TPI's Avatar
Car: 1985 IROC-Z
Why....I would almost bet you would never see a difference in milage by plumbing to the manifold. Better off maintaining tire pressure if you are that concerned with getting milage.
Old Jul 8, 2005 | 06:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
GM designed the charcoal canister to do exactly what you're trying to do. If they could have done away with it and used a line to the intake, I'm sure they would have.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
