performance
Car: 1992 trans am
Engine: 305 tpi
performance
i have a stock 1986 iroc camaro with the 305 h/o motor and auto trans, but i wanted to know what kind of performance upgrades i could do to give my car enough ***** to smoke the tires off, the rear tires are atleast 10inches wide they even hang off the side of the car a bit, but it still looks good because their mickey thompsons(car came the way it is will have pics later) i jus wana smoke the tires of like theres no 2morrow.
plls help.
plls help.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Lots of stuff. Probably the easiest and simplest first mod is a catback. Then start searching around TGO.
And if you have an auto, you do NOT have the H/O motor. Those were only available with a 5-speed. You probably have an LG4 if it's a 4bbl V8.
Car: 1992 trans am
Engine: 305 tpi
camaro
its not injection its carburated 4 barrel. but i thought all irocs were 305 h/o? would it still be a 305 even though it's not an h/o??
Car: '72 Chevy Nova
Transmission: TH350
Yes, if it doesn't have "5.0 Liter High Output" badging, and it's an auto with a 4bbl carb.. That means its an LG4 305 motor.
Transmission: 4L80E/4L80E
Yes, please update your user profile.
(Just to verify, check the eighth character of your VIN - most likely, it's an "H".)
Pac J
May 17, 2020 10:44 AM
