Intake porting bits...
Old Sep 18, 2001 | 11:07 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Has anybody ever used summit PN SUM-900240 carbide bits. It says they're ideal for iron, but would it be OK on aluminum or is the design different for an alum. bit?
thanks...ed
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Sep 18, 2001 | 11:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not used them, but I'd suggest the cheap Harbor Frieght carbide bit set for Aluminum, don't even try them on cast iron, or you'll have nothing but a mandrel with a nub on it
Old Sep 19, 2001 | 04:29 PM
JETHROIROC's Avatar
Ed, I've always used HSS cutters for porting aluminum, from the cylindrical bits to the cone-shaped ones, and the nice rounded cone one in between. Try those and don't run them too fast (> 10-15K RPM) or they will clog up with chips.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
