What year did they stopping making the L69?
Old Apr 29, 2001 | 02:38 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am trying to figure out why gm has 4 chips for the 86 five speed cars, I need a chip to go along with my 5 speed swap, and I want one from a after market company, but I need to give them a code and I don't know which chip code to give them, I have a lg4 car, that now has a 350 and a 5 speed insted of the 305 auto.Thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Apr 29, 2001 | 02:44 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
1986 was the last year for the "G" (L69) motor.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 29, 2001 | 04:08 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Well, technically, the L69 was made until 88' in the Monte Carlo SS. It saw roller lifters and center bolt valve covers. But 86' was the last year it was in the F-bodies. There were very few built, I forgot the number, but it was around 50.
As for the different chips, most likely it was for the LG4 and the L69 for either 49 states, or California. Also, the LG4 that came on the Iroc/Z28/Trans am had the timing set at 6 degrees, but all the rest were set to 0 degrees so they could run 87 octane. That could be another reason for a different chip.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Apr 29, 2001 | 05:46 PM
Biochem's Avatar
Car: 2002 SOM z28
I have a Stage II Hypercrap chip that I got from a friend about a year ago. It wouldn't work on my LG4 nor my 350 because I don't have a knock sensor. I am pretty sure it will work on a L69 especially after like 83-84 or so when they started putting knock sensors on these blocks (at least that is the way I understand it).
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 29, 2001 | 09:30 PM
BLACK Z's Avatar
Car: 86 Z28
Are you trying to get rid of the chip? what is the part number? is it for a 5 speed car or a auto?
Old Sep 19, 2001 | 08:20 PM
BLACK Z's Avatar
Car: 86 Z28
Can I use a l69 chip?
Ghettobird52
Jul 5, 2024 11:18 PM
jklein337
Sep 19, 2018 06:23 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
