how did this happen
Old Jul 9, 2005 | 01:58 PM
camaronick91's Avatar
Car: 91 z28
Engine: 350 stealthram
anybody know alot about the tps
last summer i bought a tps senor from napa and set the volts to .60 . checked it this week and was at .39. when i went to set it back i only got it to go up to .52. what are some possible causes. how could i get it back to .60?
Old Jul 10, 2005 | 10:16 AM
Vader's Avatar
It was my impression that the TPS on the 90-92 TPIs are non-adjustable. As long as the voltage is below 1.0V at startup, there should be no problems.
Old Jul 10, 2005 | 10:33 AM
92_ZED's Avatar
Car: '92 Z28
As Vader states there isn't a need to adjust it (this is for the '90-'92 SD setups). However, since it is changing it may be caused by a sticky throttle body shaft or throttle cable. Something to check.
Al.
Old Jul 10, 2005 | 02:37 PM
Car: 91 z28
when u say their non adjustable does that mean the computer adjusts to what ever the tps is set at. because i had it set at .50 orginally and raised it to .60 and noticed and big difference in the sound of the engine. and my a/f guage was reading richer than before. my concern is that im running lean at wot. i dont even get a reading at idle.i know i might have a vacuum leak some where but should that effect a/f at wot.
Old Jul 11, 2005 | 07:40 AM
92_ZED's Avatar
Car: '92 Z28
Yes, the ECM keeps track of the lowest TPS reading and uses that as 0% TPS. Everything is based on the 0% TPS value.
Al.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
