Springy noises?!?!?!
Old Sep 18, 2001 | 08:56 PM
duke_mushroom's Avatar
I've just noticed it lately. My car is making some kind of wierd springy noise. I cannot figure out where it's coming from. It's really been more annoying than hurtful(or will that change)? Oh yeah, and what do you guys think. I found a complete 383 that has been dynoed at 500HP with certain mods for $1800.00. Or a block that has been machined to be a 383 for $750.00. I've really been wanting to build the engine myself, but if I can get a complete 383 for so cheap, i'd think I should go for it, what do you guys think. Here's where I found it.
www.enginemachine.com
Thanks.
Old Sep 18, 2001 | 09:54 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Almost sounds to good to be true.
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Old Sep 18, 2001 | 11:17 PM
I know, I figured that that was just for a basic motor. If I want anything special done to it, it'll probably cost more.
But anybody, any ideas on the noise?
Old Sep 20, 2001 | 02:14 PM
Does anyone else have an opinion on these noises?
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
