help with speedo
Old Jul 10, 2005 | 12:03 AM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
help with speedo
not sure where this should go but umm my 88 firebird had a 145 mph gauge in it and a 8000rpm tach and i switched it to a 140mph gauge and a 6000rpm tach cause they didnt have 145 and 8000 but anyways i want the tach and speedo to be right so where could i go or what can i do to get them recalibrated?
Old Jul 10, 2005 | 06:26 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Not sure about the tach, but the speedo can be changed by changing the speedo gears. They are located toward the rear of your transmission. Its not that hard to do but you need to know which gears to use. Do a search on the board for it and there should be a site that calculates for it. It all depends on tire size and gear ratio.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
