LT1 Pushrods
Old Jul 11, 2005 | 01:51 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
LT1 Pushrods
Are LT1 pushrods better then stock L98 pushrods. Just wondering cause i can get a set for free used of my buddies '95 LT1 along with some Comp OE lifters to freshen up the heads along with some 1.6 Roller Rockers. And out of curiosity what are good replacement valve springs. Cam is stock but while im there might as well freshen everything up if its cheap. Car only has 110K Km on it which is like a lil over 65K miles. Do i even need them?
Old Jul 15, 2005 | 10:24 PM
Vader's Avatar
Basically the same push rods. If you have some good L98 push rods, keep them. If you want to upgrade for better springs, go aftermarket.
Old Jul 15, 2005 | 10:30 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
rods are rods some are hardened other aren't the main difference is in the rod ends
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
mfp189
Sep 27, 2015 09:25 AM
