Oil Pressure Question! Help!
Old Sep 20, 2001 | 08:01 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
I own a stock 87 Iroc (5.7L). When I first bought it the oil pressure guage would go up a little past 30 when I started it up then after she warmed up fall back to around 30 (or a little lower). Then I decided to change the oil, I used 10W30 instead of the 5W30 (I am thinking this wasn't a smart thing to do, looking back on it), now the oil pressure goes up to the stroke below 60 and stays there until the engine has been running for a long time... whats on the go..should I change my oil???? Will this cause any damage to the engine??????
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
350 TPI
TH-700R-4 Tranny
"Better to look at it than to look for it "
Old Sep 20, 2001 | 08:21 PM
j166a99's Avatar
40-60 psi is where you want to see it when in motion. it should drop to 30 only at a complete stop or idle.
you're good now...that's the oil grade i use 10w30 Castrol.
'86WS7
Ram Air...
*EiyseWhite*
Old Sep 21, 2001 | 07:26 AM
Biochem's Avatar
Car: 2002 SOM z28
Be happy... mine can drop as low as 15psi@ idle when it gets warm!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Sep 21, 2001 | 09:24 AM
ede's Avatar
ede
you don't have a problem, it's a good thing.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 21, 2001 | 12:47 PM
87ROCZ's Avatar
Thanks guys!! Phew!!
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
350 TPI
TH-700R-4 Tranny
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
