Primary coolant fan question!!!!!
Old Sep 20, 2001 | 08:07 PM
Like a ROC 89's Avatar
I have an 89 Iroc with the L98. It has the dual coolant fans. When I first start the car the primary fan runs for almost 30 secs and then turns off. It comes on and off normally then during regular driving. There is no SES light on, and I have looked for codes but found only code 12 which is normal.
Old Sep 20, 2001 | 09:05 PM
Vader's Avatar
ROC,
Does the engine start and run easily when cold? I'm thinking you might have a CTS that is "flipping out". It may also be a CTS wiring problem, but that shouldn't change when the engine warms.
That IS a strange one you have there...
Later,
Vader
Justice and Freedom will Prevail
Old Sep 20, 2001 | 09:11 PM
The engine runs fine but shakes slightly at idle but nothing bad. I replaced the CTS with a GM replacement and the wiring looks good. The car has 62K miles on it. Also the car has the ARAP prom in it with nothing else done with it except to reverse the fan turn on logic, but I dont think that would make a difference. It seems as though it is some sort of diagnostic for the fan??
Old Sep 20, 2001 | 11:31 PM
BTT
Old Sep 21, 2001 | 10:08 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
My '89 has done this since new, two or three different PROM updates, one different ECM and a different CTS, all for different problems, but this "problem" has always been there, off and on. Sometimes when the engine is stone cold from sitting all night, and other times after a warm start.
My fans only stay on for maybe 5-10 seconds max, if I recall.
Old Sep 21, 2001 | 12:57 PM
Now that I think about it, it is really only about 10secs that they stay on. But that is weird???? Maybe its an '89 thing??? But it never did this before I put the ARAP chip in?????
eightsixseven
Dec 16, 2024 01:50 PM
Bstrang6
Sep 8, 2015 04:29 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
