Knock Sensor, Where is it?
Old Jul 11, 2005 | 09:58 PM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
I'm getting a code for my knock sensor but I've never played with one before so I don't know where it's at. All I've figured out is that I have to drain the cooling system before I change it which I'm assuming it means its towards the bottom of the block.
I've got a 92 Firebird 350 TPI
Old Jul 11, 2005 | 10:18 PM
klumb15's Avatar
no need to drain coolant I don't think...i can't rememeber if i changed mine before i dumped coolant in or not...look on the passenger side of the block, right in front of the starter...it looks kinda like a fan temp sending unit...i
Old Jul 12, 2005 | 11:53 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
thanks for the help
Old Jul 12, 2005 | 11:58 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
You'll probably want to drain the coolant. The knock sensor is basically acting as a block drain plug for your block's passenger side. You'll see a plug in exactly the same place on your driver's side. They both drain coolant from the block.
When I did it on my car, I didn't drain the coolant and ended up with quite a mess to clean up in the garage.
Old Jul 12, 2005 | 01:14 PM
klumb15's Avatar
haha...i must've put the new one in before i put all my coolant in...mine was nice and dry
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
