How do I fix my air conditioning???
Old Sep 21, 2001 | 09:12 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
It went from full blast to only barely getting air out of the vents,can I recharge it??
Drive it like you stole it
Old Sep 21, 2001 | 05:14 PM
91'firebrd's Avatar
If alot of air is coming out but it isn't cold then your system could be low on freon but if it seems the fan is stuck on low, blowing cold but just not enough air coming out then its your blower motor. There could also be a problem with the relay that the hi-lo fan dial works but I doubt it.
Old Sep 21, 2001 | 05:56 PM
IROCME's Avatar
Car: 1986 IROCZ
how much is a blower motor and are they hard to get to/swap out???
Old Sep 21, 2001 | 10:18 PM
breathment's Avatar
im pretty sure they are under the hood, so it wouldn't be too hard. But make sure that the air isn't also coming out of the lower vents and the defogger vents. Mine sometimes when i put it on MAX it acts like its on bi-leval and therefore not as much air comes out.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Vintageracer
Jan 10, 2020 05:33 PM
dyeager535
Aug 28, 2015 08:10 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
