305 power problem
Old Jul 13, 2005 | 07:10 AM
Skull88's Avatar
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
305 power problem
I have a 87 camaro and every time i step on the gas it feels like i'm going slow and it accelarates slow to. I don't keep up with 4 cylinder cars or any euro car. Can someone please tell me whats wrong with my car.
305 (stock)
Carb.
Old Jul 13, 2005 | 09:28 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
like you punch the gas to the floor, or lightly push the gas as well?
Check the A/V tension, look at the main page of TGO under the tech articles to check this.
-J
Old Jul 13, 2005 | 10:19 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Has the carb been adjusted lately? More importantly, is the catalytic converter clogged? You can tell by looking at it. If it's glowing red, you just found your problem. More things to check are:
1. Has it had a tune-up recently?
2. Did this begin after the tune-up?
3. Have you changed the charcoal canister filter? (Dirty ones will
cause a loss in torque, believe it or not!)
4. Are your brakes binding?
5. When was the last time you changed your fuel filter?
6. Have you checked your timing?
If you check all these things, you'll probably find your problem. If not, then it's time to do a compression test to make sure your cylinder pressures are right and you don't have bad piston rings or a blown head-gasket. More than likely, you'll find one of the simple fixes will fix you right up. Hope you get her figured out.
Old Jul 13, 2005 | 11:38 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I'll add a few more.
1.)Is the in-tank booster pump functioning
2.)Is the transmissions TV cable adjusted properly
3.)What is the condition of the fluid
4.)Don't overlook cam wear problems
5.)Check to be sure your secondary cam is intact and raises the metering rods when you open the air valves.
6.)Check your EFE valve and Thermac Valves for proper operation.
Old Jul 13, 2005 | 11:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 power problem
Originally posted by Skull88
305 (stock)
Carb.
That could be part of the problem. What are you expecting?
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
Brcharrelson
Aug 26, 2015 07:47 PM
