Putting steering shaft back onto the box....
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Well im putting a new power steering box in but having a heck of aa time getting the splined shaft back onto the box. anyone have aany suggestions on how to do this??? This is an in-car install. the shaft is stil attached, the box is lose. any help is greatly appreciated.
1988 IROC-Z L98
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, AFPR, MSD-6A, MSD Blaster 2 GM Coil, bored .030 over.
Nitrous System:
NOS Plate Kit, 100hp shot.
Suspension Mods:
Lakewood Traction Action Lift Bars, Hal Rear Shocks
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter
ET: 13.833@99.30 N/A
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
1988 IROC-Z L98
Engine Mods:
Nitrous System:
Suspension Mods:
Trans Mods:
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega ShifterET: 13.833@99.30 N/A
www.mfba.org
when i changed mine to manual box i bolted up the box and the "intermetiate shaft" was the one i used to connect to the box and the stearing column. i used a wire brush to clean up the splines a little but don't recall having any major problems getting it to match up or slide together.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: yep
Engine: uhuh
Transmission: sure does
The spline is a "D" shape, sure you are lining up the d?
Try using a big screwdriver and opening the slot on the bottom of the rag joint, by where the bolt goes through.
I usually remove the 2 bolts on the rag joint with the box, this way you can do the spline thing on the bench.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
backtothe80s
Sep 5, 2015 12:39 AM
