Engine question
Old Sep 21, 2001 | 03:43 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Engine question
I found the engines id-number its V08260HE. Is that a 305 or a 350?????
Old Sep 21, 2001 | 07:18 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You need to get the number on the rear drivers side of the block. Between the top drivers side trans bolt and the second trans bolt. (3970010 for example.)
IIRC, the VO number tells you where and when the block was made, and for what vehicle. You could try to break it down and figure out the size, but its easier to get the other number and go to www.mortec.com .
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited September 21, 2001).]
Old Sep 23, 2001 | 07:47 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Hmmm cant find that number so i guess i cant figure out what engine i have. Maybe someone can help me to break it down.
Old Sep 23, 2001 | 11:03 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
V = Flint Mich.
08 = August
26 = 26th of the month
OHE = the engine suffix code. You need to find out what the suffix codes are for 3rd gens, this will tell you what you have. (Mad mikes site doesnt do 3rd gen codes anymore )
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
