Ok I got a question for y'all
Old Sep 23, 2001 | 01:50 AM
89Irocz23's Avatar
ok well I have this weird noise from my car sometimes. I have a 89 Iroc Z with 350 TPI Auto. Well when I turn it makes this weird noise right under me like the tranny or exuast is rubbing or hitting something and I can not figure out what it is. Also when I slow down at a light it has this popping kinda noise right under my shifter I guess. I looked under my car to see maybe if my tranny mount was bad, but it looked ok. I dunno if u can tell if its ok by looking at it or not. It doesnt make any noises while im cruising or anything. Anybody have a clue on what this might be or anyone having the same problems? thanks
Joey
Old Sep 23, 2001 | 02:17 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
to check your tranny mount with the car jacked up of course, put a jack under the rear of the tranny where its solid, or put a board under the pan and raise it that way, jack up the tranny a little bit and see if the mount seperates, its sometimes hard to tell if the mount is broken, this way you can see. lil jay
Wide Open Till You See God...Then Brake
Old Sep 23, 2001 | 11:39 AM
89Irocz23's Avatar
ok I think I found the problem. Well the 2 bolts that are on the mount that actually bolt to the tranny were finger lose. I tighted them and ow whenever I hit the gas it makes a sqeaking noise for a second. At least it to hit my floor board now.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
