need help choosing cam for supercharger
Old Jul 15, 2005 | 09:34 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i blew my 350 so im building a heavy duty 383. forged crank, rods, pistons... with 8.5 cr. after i get the engine running im going to install a nitrous kit and use that until i get my supercharger. does anyone have any suggestions on a supercharger cam that would work well with my setup? i have ported dart ie pro 180 heads, hsr manifold and hedman lt headers. i wanna take the car a little past 6k, probably to around 6200 rpms or so. anyone have any suggestions on a cam that would work well? thanks for the help guys!
Old Jul 15, 2005 | 09:57 AM
ede's Avatar
ede
it's pretty hard to set and engine up for nitrous and then switch to a SC without starting over.
Old Jul 15, 2005 | 10:40 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
w/e... it was just an idea. i'll probably just run around in the car for a while n/a with low compression and the s/c cam until i get the s/c itself. got any ideas on a cam?
Old Jul 15, 2005 | 02:25 PM
firebirdjones's Avatar
cams
Best bet is to call Comp cams and give them your combo and what you want to accomplish and they will custom grind one for you. It does not cost any more than an off the shelf cam and you will get something better suited for your combo. I have Comp cams custom grind all my cams for my cars and they usually arrive at my door in 3 days for the same cost of something out of a catalog. They have pretty quick turn around. Larry.
Old Jul 15, 2005 | 09:01 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
For a hyd flat tappet NOS/ Blower cam This one is your friend
Don;t ask questions. Just buy it and install it and go.
Been there , done that.
Jorlain
Oct 8, 2015 01:57 AM
tommy z-28
Oct 6, 2015 10:58 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
