Gas leak
Old Jul 15, 2005 | 03:50 PM
Spiers's Avatar
Gas leak
Only when my tank is full or almost full, gas leaks out of the driver side. Especially if the drivers side is sitting lower than the pass. side. Ive searched some and saw something about a recall. Please help.
Old Jul 15, 2005 | 04:36 PM
Damon's Avatar
I'm guessing there might be a leak where the filler neck meets the tank? Not sure about a recall but I never had this problem.
Old Jul 15, 2005 | 07:19 PM
Cole's Avatar
I've never had this problem either, but you may be able to look and see if it is leaking at the joint where the filler neck meets the tank by removing the shroud inside your gas filler door and having a look. It sounds like the likely source of the leak to me too.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TBRays98
Sep 6, 2015 05:05 PM
tgp1990
Sep 4, 2015 06:24 AM
