rocker arms??
Old Sep 24, 2001 | 11:16 AM
92zeddar's Avatar
rocker arms??
would I gain anything at all by putting 1.6 roller rockers on a basically stock 305TPI?
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Hypertech chip
5 speed
Old Sep 24, 2001 | 12:05 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You would and about .032 lift to your cam,but you may have to elongate the pushrod holes in your heads to make them work. For what you would gain I would not say its worth it.
Old Sep 24, 2001 | 02:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Putting good quality real rockers, and getting the sheet-metal crap off of there, will make an immense difference. However, it will make very little difference whether you put 1.5 ratio or 1.6 ratio rockers on it, except that with the 1.6s, you may have to do some machine work.
So definitely put some better ones on there. I'd recommend the Comp steel roller-tip ones, they're a good bang for the buck type of thing.
ICON Motorsports
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
