Is there a way to tell if a fuel pump is going bad?
Car: 1987 Z28
Transmission: 700-R4
The subject says it all. Im 99% sure my injectors are bad, and i figured with 92,000 miles the fuel pump might be going too.
Car: '89 GTA
Engine: ZZ6TPI
Some make noise before they die, mine didn't. I went out to start it one morning and it didn't work. There was no other warning. The only way to really know is to put a fuel pressure guage in the car and see if it holds pressure at WOT.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
Car: 91 Formula, 92 Vert
Engine: 350 TPI, 350 LT1
Transmission: Both Auto
You can tell when your car feels like its running out of gas but you have plenty of it in the tank.
And then when you have the key to the on position before you start the motor you should hear the pump prime. And you can push on the valve stem of the shrader (sp?) valve on the fuel rail and it should squirt alot of gas.
Trevor Myhre
91 Firebird Formula-
Built 355 w/ ATI ProCharger P600B 12psi, 2 core intercooler.
Pro-Built Stage 3 700-R4 w/ Continental 2400 stall TC
C5 wheels and tires.
92 Firebird Convertible-
TBI 305 w/ L98 cam, MSD 6A, Open Element, Free mods
700-R4
WS6 wheels and tires.
Me, my car and I
"Speed kills but it makes me feel alive" - White Zombie
Crazy street-racing idiot member of the All-Powerful Nor-Cal crew.
Trevor Myhre
700-R4
Me, my car and I
Damnit, if you think its going, like pretty sure.
DO IT!!! or get ready..
that when Whe your on a FREKIN date to a Homecomming Dance With a near 70$ detail clean job on it, and after taking pics in sunset, driving back to the FREKIN resturnat, The CAR DIESS!!!!!
BAD MONKEY!!
oi, sorry, im done...
be careful, mine did, occasional at WOT on the road, it will throw code, youd slam on gas, but no true power....
Whats a pulsator on the thing??
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
BAD MONKEY!!
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... Thread
