question about 91 firebird!
Old Sep 24, 2001 | 02:19 PM
SPEEDBOX's Avatar
whats up y all
I got a little question ill appreciate it any help
i have a 91 firebird 305 tbi and im wonderin if all the rubber hoses and some little things located on the passenger side of the engine, right above the exhaust, are necessary or if they just make the car slower
they seem to conncet with the exhaust and I wanna install headers and Im wonderin if i can get rid of them
ill appreciate all responses
laters
SPEEDBOX
Old Sep 24, 2001 | 04:11 PM
Enkil's Avatar
All the rubber hoses and things? hmm. That's very vague, so.. I'll do the best I can.
For the most part, you want to leave all the rubber hoses in place. The rubber lines are often vacuum lines and if disconnected can cause the car to not idle right, perform badly, etc. Of course, you can fix a vacuum leak by plugging it off, but a lot of parts of an engine are driven by a vacuum, so be sure you know what you're disconnecting.
There's two heater hoses that are fairly obvious, I think they say "HEATER HOSE" on them somewhere. heh. They can be disconnected, but realize of course that you won't have any heat. AC will still work though.
There's hoses running from the air pump to the exhaust manifolds and the catalytic converter. These you'll want to leave on if you're living in an area with emissions inspections. The cats in our cars require air to properly function.
There's some radiator hoses, of course you'll want to leave those in place.
There's a lot of electrical wire incased in rubber/plastic rubing, don't cut that... heh
I can't think of what else is down there really.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Sep 24, 2001 | 09:44 PM
FiReBReTHa's Avatar
nice to see another one!!!
mines in my link, if ya got questoins jus email me cause i prob wont find this post again.
Gluck...
oh, and if you wanna remove allot of things from your bay.
go get a blender and pull out your engine, replace hood, your good to go!
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Sep 24, 2001 | 10:48 PM
SHE DVL's Avatar
Speedbox, I'm assuming you're referring to the air pump and all it's hoses. Yes, you can take it off, assuming you don't have to pass emissions. I've removed all that junk from both my thirdgen f-bodies and haven't had a problem with the idle on either one. On my firebird I used brass plugs in the exhaust manifolds. On the camaro I have headers, so I had a buddy cut off and weld shut the metal lines going to the primaries. Removing the emissions stuff probably won't make the car significantly faster, but the engine bay will look lots prettier, and you'll be able to change the sparkies much easier too. Here's a pic of the camaro's engine bay. You can see how much cleaner it looks without all the hoses and stuff.
http://www.fbody.com/members/ViciousZ/Engine1.JPG
Michelle
92 Formula 350
91 Z28
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
