Code 14 and 41
Old Jul 18, 2005 | 10:07 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Code 14 and 41
I have a couple of questions about some trouble codes i pulled from my 84 cc carb, L69. First code i got was 14, I cant find a 84 specific chart, 86-87 said it was "Coolant temperature sensor signal indicates a temperature of over 275° F for 2 seconds." Now i dont know if this is correct for a 84 model, i would like to know if it is or not and how to correct this.
Second i have a code 41, and I couldnt locate any info on this one, also from the 84. Any insight would be greatly appreciated.
Kevin
Old Jul 19, 2005 | 07:53 PM
Engine: 383, L69
ttt anyone know the codes or direct me on where to look.
Old Jul 19, 2005 | 07:58 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
Don't want you ignored, hate that. Per the haynes Manual, 82-92. Code 14 Circuit/System=Coolant Temperature Sensor Circuit, indicates Engine Overheating, poor electrical connection, open or short in circuit, defective coolant temperature sensor, defective ECM. Code 41 Circuit System(carb models) = No Distributor Reference Pulses to ECM with Engine Running, indicates poor electrical connection, open or short in circuit, defective distributor pick up coil, fault in the MAP or differential pressure sensor circuit. Troubleshooting is the process of elimination. Good Luck! PS, Keep those coal trains amoving.
Old Jul 22, 2007 | 12:29 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Code 14 and 41
Check your connector to the coolant temp sensor (front of intake on most cars?). A bad connection here will make the car think overheat. Is the car running hot, smell hot, coolant system making funny noises? If not, it's probably just a bad wire/connector/sensor.
Good luck
TA
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
