Please help..very very bad situation..
Old Sep 24, 2001 | 08:13 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
Alrighty here it goes..I went to go start my camaro on sunday and when i turned the key the engine started to crank then i heard a *boom*. I had the hood open and could see smoke coming out from around one of the spark plug wires at the boot near the engine..Now I thought I might have fried the wire so i put a new one on and now the car just wants to start but just can't. It seems like it's struggling to fire..Does anyone have any idea what this is? I'm kinda worried about the car..Any and all help is appreciated.
"Turn a 12 second dream into a 10 second reality"
Old Sep 24, 2001 | 08:21 PM
Xenodrgn's Avatar
First off... start with some info about the car, what year, what engine... ect. Then go ahead and do some looking for yourself, take the plugs out and read them, especially the one from the smoking hole... get back to us with some more definitive info instead of "*boom*, smoke".
(no flame intended)
Old Sep 24, 2001 | 08:43 PM
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
(no flame intended)
</font>
Thanks for making me sound like an *******..anyways..it's an 87 IROC 350 TPI..That's all the definitve info I can provide..
Old Sep 24, 2001 | 09:56 PM
breathment's Avatar
was the engine warm or cold when u started it, like had u started it yet that day? and did u try pulling the plug?
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 24, 2001 | 09:58 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Would kinda seem like you had an intake backfire...question is why, and what may have been damaged?
Could be the backfire took out the MAF sensor, there is a screen in it to prevent a backfire from damaging it, but who knows?
Try unplugging the electrical connection on the underside of the MAf sensor (it'll be the roundish tube looking thing behind the aircleaner plastic. Undo the little clips that hold the snorkel down, gently lift up on the plastic "Y" (good time to change the air filters while you're there) and undo to connector.
If it starts up, then you've found one problem.
Next need to find out why it backfired.
Question, you say you had the hood up? Why was the hood up? Were you working on something, etc?
Gonna have to change my screen name to 8TYPO-KING9
[This message has been edited by 8Mike9 (edited September 24, 2001).]
Old Sep 25, 2001 | 05:12 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
are there still fusible links that go to the main power wire on an 87???
zroc
Old Sep 25, 2001 | 02:16 PM
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
</font>
Thanks for the opinion..I had just popped the hood cause I was planning on putting new plug wires on the car but i decided to start it up and let it run for a little bit since it hadn't been started in almost a week then wait and do the wires later...That's why I had the hood open...then the fateful event occured. I'm hoping it's just something stupid that can be fixed easily..I'll try playing around with the MAF sensor when I go see the car in a couple of days..
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
