Dead Deashlights
Old Sep 25, 2001 | 06:12 PM
tommy17's Avatar
Dead Deashlights
Hello all. I'm hoping for a little help here. When I left for work this morning and put my lights on, I noticed that my dash lights were all out. I changed the fuse and it popped immediately. Any idea on what could be shorting out all of a sudden ?
Old Sep 25, 2001 | 07:13 PM
camaroguy99's Avatar
You have a short somewhere on the circut. It looks like the dash is comming apart... good luck
Old Sep 25, 2001 | 09:51 PM
z2hate's Avatar
also could be bad headlight switch
86 IROC-Z
305 TPI
th350
flowmaster exhaust
chip
Old Sep 25, 2001 | 09:55 PM
tommy17's Avatar
Where do I start looking ? What am I looking for ?
Old Sep 25, 2001 | 10:19 PM
Changa2's Avatar
Pull your Cigar lighter. For some reason that is the source for some unexplained fuse problems. Just a WAG.
Old Sep 26, 2001 | 11:09 AM
82camaro's Avatar
Car: 82 camaro SC
Your cigarette lighter and tail-lights are on the same circut. A shorted out lighter and/or tail-light bulb can cause this problem.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 26, 2001 | 12:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The power that lights the lights comes from the tail light circuit of the headlight switch (that's why any time the tail lights are on, the dash lights are too); if it's a Camaro, it goes to the dimmer pot; in wither car, it goes to the fusebox; if it's a Firebird, it goes to the dimmer module and then to the lights, if it's a Camaro, it goes straight to the lights.
The cigarette lighter cannot cause the dash light fuse to blow, nor can the tail lights. Ignore that suggestion. They are on 2 separate circuits: the cigarette lighter is on the same circuit with the dome light, and the tail lights have their own circuit, with their fuse after the switch downstream of where the dash lights get their power.
I'm going to assume that you're working on a Firebird, because it's all but impossible for this to happen in a Camaro unless somebody has sodomized the wiring which would most likely occur around the radio. If somebody did a typical ghetto install by hacking the wires and left the instr lamp wire that goes to the radio hanging someplace bare, it could be touching something. Otherwise, if it's a Firebird, you probably need a dimmer module.
ICON Motorsports
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Johnoooooo
Sep 22, 2015 08:55 AM
