couple quick questions
Old Jul 20, 2005 | 06:49 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
wheres the front grounds for the block go on the block?
here does htis connector plug into (see pic)
how the hell does this bracket go with my starter? is it even for my starter? (see pic [my buddy took the starter off so i dont remember how it goes on])
Old Jul 20, 2005 | 06:51 PM
Borsty's Avatar
Car: 89 Trans am
and does anyone know what the front vac line son the TBI go to? all except the PCV vavle one?
and wat this is for?
Old Jul 20, 2005 | 10:30 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The first picture is the transmission electrical connector for the TCC. The second picture is the starter brace (looks like he took a bolt from your starter with it, don't leave that out); its a useful piece and should be retained, as it helps support the starter, keeping stress from the nose... There is a bolt hole for it right above the oil pan rail on the block near the rear of the starter (once bolted up)..
The third picture is a picture of the EGR vacuum solenoid. One side of the valve hooks up to the ported vacuum on the front of the throttle body (TBI), the other side goes to the EGR valve. I think the thermac door on the air cleaner hooks up to the other port on the throttle body, but its been a little bit since I took one apart.
EDIT: pretty headers, btw.
Old Jul 21, 2005 | 04:14 AM
Borsty's Avatar
Car: 89 Trans am
thanks, i dont have egr thou lol.
since u said pretty headers might as well show u the rest
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
