gotta weird engine or tranny issue
Old Jul 21, 2005 | 02:24 AM
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
whenever im driving along in OD, and i am around 70 mph (4th gear) around 2200-2400 RPMs, i get this "surge". the tach will show a "spike" up to about 2700-2800. it lasts for a fraction of a second... but u do feel/hear this small surge. if i stay in the 2200-2400 rpms range it will happen once every 30-40 secs. i dont get any engine codes on the drive, and whe i check, it doesnt show anything. any idea what could cause this?
Old Jul 21, 2005 | 09:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like the torque converter is unlocking. Could be a solenoid power issue, such as your brake light switch, or a circuit ground issue, or a mechanical problem with the converter.
Check your fluid level for starters.
89gtaforsale
Aug 24, 2015 09:32 PM
sreZ28
Aug 14, 2015 07:48 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
