Engine Plug ID??
Old Jul 21, 2005 | 02:43 AM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Engine Plug ID??
Looking for places to mount oil temp and pressure senders and I found this plug (see attached).
I need to know if its under pressure or not as it would be ideal for the pressure sender.
Old Jul 21, 2005 | 02:45 AM
Another shot. Its just above the sump line.
Old Jul 21, 2005 | 02:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's a coolant plug, not an oil plug. There are ports at the top rear of the block near the distributor, and on the driver side directly above the oil filter that you can use for the pressure gauge. For temperature you're probably going to have to stick the sender in the pan to get an accurate reading.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
