wont run warm
Old Jul 21, 2005 | 01:23 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
wont run warm
I was driving on the free way goin about 60 or 70 and floored it to pass sumone. when the car reached high rpms it died. i pulled off to the side of the road and tried to start it and it would start and idle very low and rough for about 10 seconds and then shut off. so i let it sit for about 20 or 30 mins and then it started up and i drove home about 15 mins away keeping the car at very low rpms. the next morning i wake up and the car is cold starts up just fine and i drive to a friends house about 10 mins away. go and hang out for about 20 mins come back out and it does the same thing with a low rough idle. let it cool off for about an hour come back out and it was hard to start still but i got it finally running and drove it home.
the next day i replaced the fuel filter this didnt fix the problem. my step dad would not let me do any further work. i was thinkin it was a fuel pump problem or fuel pressure regulator. so we take it down to the mechanic. they test the fuel pressure and its fine and they find that a fuel injector was shorting out. so they fix that but the car is still doing the same thing. do you guys have any ideas? the stupid mechanic has had the car for about a week and im probably gettin charged hundreds of dollars for labor because they cant seem to find the problem. any ideas? ur help is appreciated, thanks.
Old Jul 21, 2005 | 08:44 PM
camaronick91's Avatar
Car: 91 z28
Engine: 350 stealthram
check your tps voltage and idle air screw on the trottlebody. spray some starter fluid in the iac opening.
Old Jul 21, 2005 | 09:46 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I had a similar problem. my fuel injectors were bad. Check the resistance on all of them, one low resistance can completely mess up the fuel delivery. When the car is running a bad fuel injector can temporarily overheat the ecm, after the car is off for a while, the ecm injector drivers cool off and will allow fuel to flow again.
eightsixseven
Dec 16, 2024 01:50 PM
stalkier
Aug 13, 2015 12:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 8, 2015 12:07 PM
