CODES and lots of them..
Old Jul 21, 2005 | 04:47 PM
STIFFLER's Avatar
Ok guys I need some help on finding out these codes.
23 Mat Sensor Low voltage (Probally the relocation to the front air duct)
33 MAP Sensor High voltage
51 Faulty or improperly installed ECM PROM
I have switched ecm's (I have a spare) and memcals still comes on
41 Cylinder selection error (checked the firing order and it looks good)
I want to solve code 51 because it might help with others..
Any help would be appreciated
Old Jul 22, 2005 | 01:41 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
sry i cant hlp much but id say your right about fixing code 51. good luck
Old Jul 22, 2005 | 11:41 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Reset, run, repeat pull.
No, not that kind you dirty old men! You know who I'm talking to!
Old Jul 23, 2005 | 07:33 AM
STIFFLER's Avatar
Tryed that and no luck.. I wish someone in the area had the same car and could swap memcal's
Old Jul 23, 2005 | 10:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your code 41 and 51 go hand in hand. Basically they mean to open the case on the computer and make sure that the computer chip is properly installed and doesn't have any bent or broken pins. It also means check to make sure you have the correct chip in there to start with.
specialized
Jun 18, 2022 09:26 AM
Toolsin
Feb 2, 2016 06:55 AM
92projectcamaro
Jan 18, 2016 08:00 AM
gta90
Sep 15, 2015 04:00 PM
ZZ42Fast
Aug 30, 2015 02:39 PM
