Start up troubles
Old Jul 21, 2005 | 04:49 PM
BlackNSilverRS's Avatar
Car: 91 RS Camaro
Engine: 3.1 V6
Transmission: 301
Start up troubles
I drove my 91 RS the other day and then pulled it in the driveway for about 3 hours until i had to go to work. When went out, the car would crank , but would not start up. There have not been and there wasnt any problems with the car up until that time, so we looked and there are no sparks emitting from the plug wires. We replaced the distributer cap and the roater button, still no start up. We then replaced the ignition module, still no start up. My question is, what else do we have to look for? Ignition coils? Sensors?
Old Jul 24, 2005 | 03:38 AM
daStingray's Avatar
Car: 89 IROC & Formula, 86 6000 STE
Engine: TPI 350's, 173ci
Transmission: TH700, TH250
Sucks you dumped all that cash on non-returnable electrical items! Been there done that!! If your certain it's a spark problem and you checked for that properly, have the coil tested also the pickup coil. It sounds like the distributor is going to have to come out.
Old Jul 30, 2005 | 04:18 PM
Car: 91 RS Camaro
Engine: 3.1 V6
Transmission: 301
yeah, ive already replaced the coil, and still no start up. Ive already bought a new pickup coil and am about to try that out.
Old Jul 31, 2005 | 04:05 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Are you sure the fuel pump is good? Test the fuel pressure. When my fuel pump went bad the the T/A it was crank and not start.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
