Vibration Help
Old Sep 25, 2001 | 07:40 PM
Trans Am's Avatar
Vibration Help
My car is an 84 ta 305 lg4 4bbl.When the car is at idle it will vibrate pretty bad and if you step on the gas a little it will almost stop vibrating but then if you go a little more it will get bad again.Please help me i almost want to sell because of this.
Old Sep 25, 2001 | 07:59 PM
john72ss's Avatar
well lets see... maybe bad spark plug wires..... carb problems..... motor mounts....fuel filter?....just a few to start with
Old Sep 26, 2001 | 10:54 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Don't forget to check your trans mount.
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
