Camaro Smoke Problem
Old Jul 21, 2005 | 10:00 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
I just found out that when you start the car, smoke spews out from the exhaust but it clears out about 30 seconds in.
Does anyone know if this is something I should be worried about? Could this mean engine trouble, or oil trouble, the oil is changed on time every day so I dont know...
Old Jul 21, 2005 | 10:04 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
are you getting a check engine light?
Old Jul 21, 2005 | 10:17 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Blue smoke on startup only is valve seals. Common problem but not a serious one. If it bugs you then change them. Try a search, there is a gazillion threads on changing them.
Old Jul 21, 2005 | 10:28 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
its white smoke. how much are the valve seals?
Old Jul 21, 2005 | 11:36 PM
Engine: SBC, LS-x
White smoke is either coolant making it's way to the combustion chamber or moisture burning off in the exhaust as it warms up. Keep an eye on your coolant level and make sure it is not going down.
Valve seals are cheap, usually under $20.
bryan623
Mar 22, 2021 06:43 PM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
