Vortec heads or no????
Old Jul 22, 2005 | 10:09 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
OK ... wow alright right now on my engine...i THINK these are the heads i have....
"cylinder heads: cast iron with 64cc chambers. this head include 1.94" intake and 1.50" exhaust valves, with straight type spark plug holes.
they are non-swirl heads.."
that came with a sheet when i bought my car about my engine.....and i was just looking at jegs online...and i looked at the cast iron vortec heads and this is wat is said abuot them.....
"Material: Cast Iron
Intake Port Volume: 170cc
Combustion Chamber Volume: 64cc
Vale Diameter: 1.94'' Int./ 1.50'' Exh.
Spark Plugs: Straight"
so im assuming i could very well have vortec heads???? could this be true?
when i get home im going to check the casting numbers and all that im just kinda looking for reassurance because i wana know i have some decent parts on my 350
*mods this post is under aftermarkert products, so if u want delete that one*
Old Jul 22, 2005 | 11:10 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
vortecs have a saw tooth pattern on the front or back of the head...i cant remember. but thats one why ive seen to tell
Old Jul 22, 2005 | 11:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the intake bolt pattern.
Old Jul 23, 2005 | 12:32 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What intake do you have?
Old Jul 24, 2005 | 03:30 AM
daStingray's Avatar
Car: 89 IROC & Formula, 86 6000 STE
Engine: TPI 350's, 173ci
Transmission: TH700, TH250
Never ASSume! If the heads are accessible to the rear. Obtain the serial# & have your friendly GM parts guy decode them. As stated above check the intake bolt pattern. More accurately, what induction is it? Vortec TPI intakes are currently only available through Scoggin Dickey in Texas and NOT cheap. Carbs usually run Edelbrock performer intakes.
I have these heads on my 409ci El Camino engine.
485 pounds torque 420hp!! Complete roller engine w/mild goodies!
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
