Cam specs what is the difference?
Old Sep 27, 2001 | 09:15 PM
86 IROCZ28's Avatar
I wanted to ask what the difference in Cam specifications ie Life Dur etc is between a 86 LB9 Cam (TPI) and a 92 LB9 Cam (TPI). I mean what is the differnce between these 2 Cams when they cam eout in stock cars if any??
The reason why I ask is that I have gone to MAP and am running a 92 Z28 TPI CHIP but the engine in the car is a stock 86 that came out in the IROC-Z.
I was thinking if it is worth my while changing the CAM that came out in the 92 Z28. Would I see any increase in performance or are they both the so called "Peanut Cams" and just not worth the swap. I don't really want to mess around with the CHIP at the moment or is there any other CAMS I could put in and get away with the image on the PROM?
So if anyone has the different specs on these 2 Cams it would be great to hear form you. BTW, if you have an idea what might be a problem with running a 92 CAM in a 86 engine can you also state that ie, like running rich etc.
Thanks!
Old Sep 27, 2001 | 09:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you look through the Tech Articles on the main page, you'll find the info you seek...I beloeve it's in an article called something like " All about camshafts" or similar.
Old Sep 27, 2001 | 10:46 PM
Guest
Guest
Posts: n/a
I think if you were to pull a cam out of a 92, you would find it isnt a peanut cam like everyone says it is. I did it on a 91 that was definitely factory fresh (gasket material and stuff... or lack thereof, just like the factory did, and the owner said so too) and it wasnt a peanut like it was supposed to be either.
Your rich running problem is probably related to a wiring problem I would guess, not the cam.
I also hope your cold start is disconnected.
Old Sep 27, 2001 | 11:13 PM
86 IROCZ28's Avatar
Yeah my cold start injector is not connected into the ECM and it Can't be either as the MAP ECM did not have a pin out on the ECM for a cold start injector.
Thanks for the Info guys.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
